Units used in tutorials
amaya_munoz
Posts: 1 ✭
In the tutorials the units used are imperial (inches), in Europe we use metric units (cm, mm, ...). Maybe something to consider when targeting your audience.
Many Thanks
Amaya
Many Thanks
Amaya
@ amaya_munoz, you can change the units for modeling by following method,
In drawing,selecting ISO template will give you units in mm and selecting ANSI templates will give you units in Inch.
Hi @amaya_munoz, in the world three countries which are not using the metric system are Liberia, Myanmar and of course… the United States of America..weird i know....when following the tutorials you can either follow @Narayan_K advise and change units or in the dimension box enter "in" even if you are working in mm and OS will do the conversion automatically
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions0 -
One downside to the global economy is that there is a far greater chance that we are using software (or other) products from countries other than the ones in which we reside and that the culture, customs, and even naming convention that are common in one can be quite foreign to the other. We hear this all the time wrt metric vs imperial dimensions and I sympathize with with those metric users of Onshape (I'm in the US). Currently, I'm making somewhat extensive use of products from Poland and Russia and have come to realize that I don't think of things the same way that they do. It can be a real struggle to adjust one's thought processes to the other's way of thinking. Eventually the global pot will be fully melted and we'll all be in the same page. Until then, we adapt as best we can.0
