Water cooled magnet coil
john_brodowski
john_brodowski Member Posts: 37 ✭
edited July 2016 in Community Support
I have no problem sweeping profiles with guides drawn on horizontal or vertical planes. SWEEP 4 is an example of sweeping profile  in horizontal plane.
When plane where sweep guides are drawn has an angular displacement with the horizontal plane the end sweeping profile has an angular
displacement. End profiles are not congruent.SWEEP 2 is an example. See the end profiles.
I tried lofting but have a problem. See LOFT 1. I have no problem lofting otherwise.
What am I doing wrong ?
Link to the coil is attached.
Thank you
https://cad.onshape.com/documents/156c99ec3a95471dae383010/w/f18840c39bce4ee68a489924/e/19b58d3bf469423d97eedb5e
