BOMs
GWS50
GWS50 Member Posts: 535 PRO
I have a BOM list in an assembly and I have excluded a few items. When trying to include these items again it appears that I have to include each item one at a time, even when selecting several rows at once.
Is there a way to include or exclude several items at once?
I did try to delete the BOM and start again but couldn't find a way to do this either.
Can the BOM be deleted?
    S1mon Member Posts: 4,613 PRO
    Please vote for this improvement request.
    To me this is fundamentally broken and I can’t understand why it was implemented this way.
  • Nath_McC
    Nath_McC Member Posts: 136 PRO
    I don't believe there is any other way to do it. With the 'exclude from BOM' property being linked to each part, you lose the properties option from the drop-down when you multi-select. It would be better if this option were connected to the assembly, and not each part.
    I found an issue where I have a part in two different assemblies, one I want in the BOM and one I don't like in the BOM; I have to keep toggling the option. If it were linked to just the assembly, this wouldn't happen. I don't use it enough to be bothered too much.
    You could request it as an improvement.
  • GWS50
    Many thanks for the info, you're right it would be better to link the BOM to the assembly, I wonder why it's not....
    It makes using BOMs a bit of a pain
