check if my first project is right and split to fit in my 3d printer
fernando_davila
fernando_davila Member Posts: 11
Hi i just draw my first drawing for my 3d printer and i need to check if i draw it right and if is possible to split in pieces that fits my printer bed
The project is a base for a collectible which has some slots where the acrylic lid will fit
here is the url of the project: https://cad.onshape.com/documents/66aadaf187de3b5c34385a0b/w/f3468052a92c5142d86d5b40/e/b1191cdee585c69967dc9cfe?renderMode=0&uiState=626384796fcbe85dad3c006f
thanks and sorry for any writing mistake English is my second language
  • nicholas_radzykewycz
    nicholas_radzykewycz Member Posts: 30 PRO
    What are the dimensions of your print bed? You can use the split command and planes to break your base into multiple segments.
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,249 PRO
    You drew it as 15 inches by 50 inches. That will not fit in any hobby 3D printer. Did you mean to make it that big? How do you plan to join the pieces together after printing? If you really want it that big, it might be a better project for a piece of wood and a router to make the groove around the perimeter.
  • fernando_davila
    Tha project is that big for that reason I need tho split it and my bed is 8,6 inches and i planning to glue it with my 3d pen or superglue
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    I think you are from a Metric country, change setting's if needed, first in your account setting's and then your document
