Problem creating a fillet between two tubes
hansrudolf
Member Posts: 57 ✭✭
Hello all,
I have an assembly, consisting of two tubular parts connected to a tee-form. One part is only a half-tube or channel, but I think that's not too important.
As I want to 3D-print the assembly, I tried to add a fillet where the two parts meet. Although I can see the curve where the parts meet, I can't add a fillet.
The error message says: Edges must form a single chain per part. I don't know what that means.
Maybe someone here can help me?
Document: https://cad.onshape.com/documents/774ecbeef87964a6c84ee914/w/2fce2c343157d117bb1faac4/e/900c05dea6d634608bada99a
(hope that works)
Thanks,
Hansrudolf
(hope that works)
Thanks,
Hansrudolf
The problem is that there are two separate bodies (one is a solid, one is a surface) in your part studio and thus you can't fillet between them. You could do an all-surface workflow - i.e extrude the outside diam of the pipes, fillet, then thicken. Or go all solids. Either way you'll need them to be a single body before the fillet0
@hansrudolf
Here is an example of one way this could work, similar to what Greg was saying:
https://cad.onshape.com/documents/7407a47401e86b634787e1be/w/f78c136b772feb7e092863e8/e/94e3a4f084711afa96876690?renderMode=0&uiState=6267f0dff82c8e064911883b
RENDERCAD
rendercad.ai - Photorealistic product rendering.
________________________________________________________________________0 -
Ok, I think I see the problem. But in my assembly I have two solids, maybe I should try a boolean and.
The plane was necessary to cut the tube, maybe I included the wrong document.
Many thanks anyway,
Hansrudolf1
