The Boolean operation did not result in any geometry changes. Either the parts have no intersection
alain_mazy
Member Posts: 30 ✭✭
Hello everyone, I can't make 1 single piece with these 4 pieces.. The error is in the title, I don't see what I can do..?
There's no real overlapping geometry between Part 3 and Part 4.
Here's another forum post with the same type of issue.
Here's another that goes more in depth.2 -
Because the parts are drafted, they are all intersecting at an edge. Onshape's kernel (same as Solidworks, NX, and countless others) will not do this. If you make the parts touch at a surface or overlap, Boolean/add will work (you don't need the composite feature).
2
