File size
michael_kerausch
Member Posts: 1 ✭
The file size of a document does not change after deleting several part studios. Why?
michael3424
Member Posts: 778 ✭✭✭✭
To reduce the file size, make a copy of the document, which will strip out all of the edits and revisions to leave you with a "clean" document. Then delete the original and you'll see that the copy has a smaller file size than the original. A "purge" feature should be coming along at some point.6
projektowanieproduktow.wordpress.com
