Reverse Featurescript Programming
adam_pullen627
adam_pullen627 Member Posts: 2 EDU
Is it possible to copy the featurescript code from a model created in a part studio? I would love to design a basic model in a part studio because of the familiarity. However, I need to create one featurescript code that will allow me to edit specific variables. This would also allow me to use one variable to correlate multiple dimensions.
  • caden_armstrong2
    caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    It is possible to view the code that creates the part studio.
    If you right click on the part studio tab in the document, there should be a "Show code" option.
    But, based on the description of your goal, a configured part studio sounds like it might be what you are aiming for.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,082 PRO
    You don't need to use the studio code directly. You can make a feature that just instantiates a part studio. So you could build your model manually with configurations (as Caden said), and write a custom feature that will derive it into any part studio based on your variables. I think it would behave the way you want.
