where is the countersink?
glen_dewsbury
Member Posts: 1,377 PRO
Ran into this just now. Asked for a countersink hole but no countersink. What did I miss?
https://cad.onshape.com/documents/12b0679a712bc6f544f72c07/w/67e973d9c8c7d9393a467fa0/e/e00742e616227d98d43069ae
Your hole diameter and countersink diameter are input as the same value. If you set the second input to your desired countersink size, you should be good.
4 -
I sent this to support and they acknowledged a need to correct.3
4 -
Kinda odd that this is the default on an M7 hole. When I switch to another size I get an expected result.
Most times the default saves me looking up countersink size. Looks like a glitch in the table values.
