Boolean operation failed to return a valid part
Hey.
When I try to use the sweep tool it gives an error, "Boolean operation failed to return a valid part.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,967 PRO
    Hi Pavel, It looks like you have faces that may be trying to share an edges or vertex. When this happens to me I usually try to start the sweep early, and pas all the way through the end.
    If you would like a more specific solution, please share the url to your document.
