multi DXF. File Export as a set
josh_mandel
josh_mandel Member Posts: 8 PRO
I would like to be able to export those 4 dxf. files as one, Is there a way to do that? It would save me a lot of time. Thanks
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,940 PRO
    I think your best bet is to create a blank drawing (no title block) and insert them in there (you can use a custom sheet size that would fit all of them 1:1), then you can export that
  • eric_pesty
  • josh_mandel
    Ok I will Try that Thanks a bunch
