How extrude curved sides?
alain_guinand
Member Posts: 3 ✭✭
Hello,
As part of a school activity, we want to model cookie cutters for Christmas.
However, I can't create a border when my drawings are made of spline. The Offset tool gives me an error message.
So, to get around this problem, would it be possible to extrude the sides of my part as shown in the drawing and not just the top and bottom of my part?
Thanks for your help!
Depending on the geometry you could extrude as a surface and then thicken to create the wall thickness, or extrude the solid and use the shell operation to remove the flat faces as needed.
Thicken (onshape.com)
Shell (onshape.com)
Onshape Senior QA Engineer0
Shell (onshape.com)
Onshape Senior QA Engineer0 -
Thank's a lot!0
