Bend information keeps appearing in .DXF export
in Drawings
Hi
I'm working on a sheet metal project that will be CNC plasma cut.
I have created a drawing file that is clear of bend lines/centre lines/bend info etc.
BUT when I export as DXF (as required by my CNC plasma cutting software) the BEND INFO returns.
How can I make an export just as I see it?
When exporting there's an extensive list of VERSIONS.... will one of these work better than others?
If I upload the DXF back into the document I can see that this BEND INFO can be turned on/off... but this is not a feature of the CNC software/post-processor that I am using.
Thanks AB
Thanks AB
The circle centres and the bend line do not re-appear..... JUST the BEND INFO ???
