How can I make this extrude match the curvature of the part?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,935 PRO
    edited November 2022
    @Logan_Neltnor, it's hard to tell exactly what to do without a link to your model. Try revolving the shape instead of extruding it. This way it matches the diameter of your part.
    Or, if you only want the outside face to match the outer diameter. You can extrude another direction, removing the outer face to match the diameter.
    RENDERCAD
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,814 PRO
    You could probably also do a "replace face"
  • MichaelPascoe
    Oh, yes. I forget that exists.
    RENDERCAD
