Help with rotating a protrusion around an edge
gyrex
Member Posts: 38 ✭✭
Hi guys,
My project is here: https://cad.onshape.com/documents/c9b5c0b4d32e5f39fe9aca73/w/43f5c8798b5fea8fb6bdcecf/e/0ea4eb965365da6436ed41a9?renderMode=0&uiState=638e1aca6330cb67c2d8eae4
I'm trying to rotate a protrusion from a circular edge around that same circular edge but I can't figure out how to do it. Here's a rough idea of what I'm trying to achieve:
Could someone please help me? Many thanks in advance....
"Rotate a protrusion" is in relocate it or as in sweep it around, adding more material? For the latter, you could revolve it or sweep it. Or even add another extrusion.
1
1 -
Thanks for your help Matt, great suggestions! I think I figured it out.Matt_Shields said:"Rotate a protrusion" is in relocate it or as in sweep it around, adding more material? For the latter, you could revolve it or sweep it. Or even add another extrusion.0
