Offset/move face into an object to create clearance?
jesse_starr
Member Posts: 15 ✭
https://cad.onshape.com/documents/c5d3a5d522294bcee608e9f1/w/d580b6282ac666a60b14ca6d/e/25aac14382f00c4ed1a90b3c?renderMode=0&uiState=638c2973f69e141166bc382c
Trying to use a boolean subtract with an offset to cut out space for an imported object. The offset will only work if I go inwards, not outwards. You can see what I mean in the failing boolean in the project.
I also tried using move face but it fails if I try to move the faces outward into the rectangular extrusion I'm trying to cut into...
Any help or better ways to do this?
The step file imported does not register as a solid to use in Boolean. When I looked at your air tag the other day it was necessary to split and use to make new sketch and revolve. That will give a solid that can be subtracted.
https://cad.onshape.com/documents/cc4403f81b731594e868e5a0/w/aede04c7d40c9d4a7a59b7e5/e/b856b4db06c145d9c3a818f4
1
