30 degree diamond knurl
S_Regula
S_Regula Member Posts: 95 PRO
I'm trying to accurately model a 30 degree diamond knurl. The 30 degrees is measured from the vertical axis. I found a way to model knurling using a helix on a cylindrical face and using a remove sweep to "cut" the groove along the helix. But, I don't see a way to define the helix based on a specified angle (30 degrees in this application). Does anyone know of a way to create a helix at a given angle, like I'm trying to do?
TIA!
