What is the fastest way to import images? (As project documentation.)
René_Sartorio
René_Sartorio Member, pcbaevp Posts: 58 PRO
Do you use the onshape document to document the project images?
I try.
My current workflow looks like this:
Take photo with iPad.
Transfer photo to oneDrive and from there to Onshape.
I think it must be easier to do.
There is the Onshape app.
Unfortunately, you can only import the images one by one. Even that did not work.
Does anyone have a better idea?
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    I don't know how it works on a mobile, but in the desktop version you can select more than one picture at a time to import.
    Maybe if you import File and you go the Folder with your pictures and multiselect your pictures
  • René_Sartorio
    I have found that the import has worked. A multi-selection for multiple photos would be nice.
