CLOSED SHEET METAL CORNER
franziska_saxer
Member Posts: 2 ✭
Hi,
I am trying Onshape for the first time. I want to build an asymmetrical body. But now I have the problem that the corners are not closed. I have to specify a bending radius of 1mm, but this is not correct in production.
Do you have a tip? How can I close such corners?
Here is the link to the file, if that helps:
https://cad.onshape.com/documents/26a7e02a56aea4f5cd8176c1/w/7611c1b73d5e368ff9643b2a/e/8aac3e6a7de378bb25fbeca2?renderMode=0&rightPanel=configPanel&uiState=63c3d5a2afad01093d922df5 0
https://cad.onshape.com/documents/4c4c28fe1eee3b9b03ad6ab4/w/be98477ccbfeab81584c9d83/e/4baf7645229b31f220e11f43
