Sheet Metal Gussets
Sam_Twogood
Member Posts: 4 ✭
There appears to be no sheet metal gusset tool like what SolidWorks has within the sheet metal model functionality in Onshape. (In SolidWorks, you simply select the two sheet metal planes across which you want your sheet metal gusset to span. I've included a link to the SolidWorks instructions below.) Is this true, or am I missing something? If there is no sheet metal gusset tool, does anyone have a suitable workaround?
https://help.solidworks.com/2021/english/SolidWorks/sldworks/t_adding_sheet_metal_gussets.htm
S1mon
Member Posts: 4,323 PRO
There are no built in forming tools yet. There are work arounds. There's this custom Feature Script which has been around for a while. I'm not sure if it will work across a bend for a gusset.
https://cad.onshape.com/documents/a752e0db24eb071ebb6f5aa0/w/47c6a6888718e30c80f1f652/e/e5c2abf7dd42d71d28468eca
Sheet Metal Gussets — Onshape
