Loft won't join to existing part
kit_jones
Member Posts: 4 ✭
Hi all,
I have a loft that won't join to an existing part and I also cant add it to the existing part using boolean.
A second loft that I have done off the same set of sketches works fine.
Can anyone have a look at this and tell me what I've done wrong please?
https://cad.onshape.com/documents/75913c9c9f568c53f359a796/w/4a34199fcc2ca4c169653e07/e/27e9b4a4f1452b63b4d4329c
glen_dewsbury
Member Posts: 1,306 PRO
There is a gap between the rib and part 1 which leaves a nonmanifold condition. Part 1 face is warped. I used a move face on the rib (0.1) to cause them to intersect. Because of the way sketch 1 & 3 are drawn only 1 of the 4 faces on loft 1 is flat.
https://cad.onshape.com/documents/843d6f66fb857ca76abf7b18/w/329de5678f63164ac750af22/e/e7a612f63e516c91b85c62b0
1
