Howto simplify my sketch?
nocry3
Member Posts: 30 ✭✭
I would like to construct the strips shown in the first picture, which follow an elipse.
In the sketch (second picture) you can see my complicated construction with a linear pattern and a manually added rectangle to intersect the eliptical construction line.
Does anyone have an idea for a simpler way?
I did not manage to bind the linear pattern directly to the elliptical construction line.
Don't do this in a sketch. Sketch one rectangle which has the corner point coincident with the curve, extrude that, then do a linear feature pattern where you select "apply per instance" so that the sketch is recomputed per rectangle.
2 -
This also works.
https://cad.onshape.com/documents/03ccec15842c6acc0933d21b/w/932047d323fed28f0126183f/e/d19b911b2138c6c16956d0d1?renderMode=0&uiState=63fa4c40dce199462ff0b3cf
I didn't show it in the gif but I would finish the sheet metal model after to turn all the parts into regular solid geometry. This method works with sheet metal because Onshape automatically keeps sheet metal edges perpendicular to the sheet metal face.4 -
I have tried to implement your solution. Unfortunately, I only get results as seen in the picture....S1mon said:Don't do this in a sketch. Sketch one rectangle which has the corner point coincident with the curve, extrude that, then do a linear feature pattern where you select "apply per instance" so that the sketch is recomputed per rectangle.0 -
