Can I add a blank dimension
derek_westwood
derek_westwood Member Posts: 35 ✭✭
Can I add a blank dimension in a layout I want to finalize or do I have to get the tippex out?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,943 PRO
    edited March 2023 Answer ✓
    Yes. To make sure we are on the same page, you must insert your Part studio or Assembly studio into a Drawing studio first. Then, place a dimension on the part. Next, edit the dimension, then put some spaces in there. There are settings to show modified dimensions with an underline; this can be changed so that there is no underline when you modify dimensions.
    RENDERCAD
  • derek_westwood
    Thanks, All.
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,370 PRO
    edited March 2023
    Blank, I don't think so. But you can over write with something like this. (TBA) To be advised.
  • MichaelPascoe
    RENDERCAD
  • derek_westwood
    Thanks, All.
