Dimension Jog Point vs. Callout Node Point?
I'm a bit curious about creating a jog in a leader line or dimension witness line. For a dimension, they UI refers to the actions Add Jog and Remove Jog. For callouts, the action is named Add Node, but there is no corresponding action named Remove Node. There is an action named Remove Leader and Add Leader which would essentially remove the Jog created with one or more Add Node actions. It just an odd workflow to use  Create Node on a BOM Balloon to add a jog and then have to use the commands Remove Leader followed by Add Leader to remove the Node(s). It would be nice if these two actions had the same name and worked in the same way so the process was consistent.
