Sheet Metal - Score Bend Line
mitch_waters
Member Posts: 2 ✭
Started working with the sheet metal tool in Onshape and found it pretty amazing. I have used Perforate sheet metal bend (smPerforateBend) which works very well. I am trying to find something similar that will preform a score line down the bend. The idea is to create an aluminium box with score lines on the bends, cut out shape on a CNC, cut score line with CNC and fold. My thought is a score line at half the material thickness will tighten the radious of the bend and allow these to be done by hand.
Anyone have any throughts or scripts?
Cheers
Mitch
Cheers
Mitch
if strength is an issue scribe of a bend line should not be done.....I plot my flat patterns and glue (rubber cement) to have easy less error prone parts.0
if you are using a CNC mill could program the bend line as shown in the flat pattern and use a small stone or end mill with say .005 depth of cut.0
