How would I make this connection between the 2 cylinders?
Logan_Neltnor
Member Posts: 3 ✭
I'm trying to make this cart, and I can't figure out how to make the 2 cylinders that is the handle connect. I am trying to figure out how to do it while have it at that angle still.
There are a lot of ways to do this.
You can construct a path and sweep a circle along it. Sketch the profile from the side, and create a plane at the angle of the handle and then sketch the top part.
Here's a quick example: https://cad.onshape.com/documents/d598b82f6785afc552491371/w/578cafa444171f4027ecd109/e/2aa858cd7ede793a26d6a7c8
This post on using frames may give you more hints of ways to do things with frames (which would make the cross bar easy.
https://www.onshape.com/en/resource-center/tech-tips/use-parts-build-frames
Good stuff from @S1monLike Simon says— This is one of those things where there’s probably a bunch of ways to do it
Here is the first thing that popped into my mind
https://cad.onshape.com/documents/d0495cbc56044cd05594bda7/w/c7835bbd2ad908c880c178b7/e/ad4f2c3dd9ec0669dfacae31
