How could I make the flange as shown?
carokhan
Member Posts: 6 EDU
Hi, I am trying to create a sheet metal flange as shown in the screenshot. Creating the angled flange requires adjusting the miter angle, however, this changes both sides. Is there a way to only adjust the miter angle on one side? Or is there a better way of accomplishing this entirely?
Thank you!
Here is the document: https://cad.onshape.com/documents/c113d62487c999928f316a4e/w/dd7ddcf5686ed02272968680/e/f598bec5e4b392dc41dba822?renderMode=0&rightPanel=sheetMetalPanel&uiState=6457c193d9ecec32a6d19ce5
A move face will get what you are describing.
https://cad.onshape.com/documents/2103b48fda9ad97518827080/w/58882f45b4a69f64c395dde9/e/ce2a4680ed4119d128a074a0
Here is another method you could try. https://cad.onshape.com/documents/2c13f8c9e21147b673d784a6/w/f6a9a2f4c96520fe7f599f82/e/6e2a7c4138900a9c937b7c67
Last, here is the cleanest Slightly different than the last: https://cad.onshape.com/documents/4fa19a9acc08e3fae5124ca9/w/009b439544d6d5b3b8051848/e/14f3d75932688b1f3a7fa458
Looking into your document, it appears to me, like you already found out, right?BTW you have a collision between the sharp-edged box profile and the bend radius.
