Creating Elbow Joint for a pipe from Sketch??
steven_han486
Member Posts: 2 ✭
I am new to onshape and CAD, and trying to learn various techniques.
I understand creating an elbow joint would be a easy task with "Sweep".
However, I thought it would be easier if I traced the side profile from an image and then somehow extrude it into a cylinder shape, which I cannot figure out how.
The main reason I did not use Sweep feature is to save the ridge at each end.
I think a revolve will get you a better start on this fitting.
https://cad.onshape.com/documents/51c56c763b52d12b01b6f0cf/w/80d72ccf515beaf60ab9a87a/e/c55a96ed27364732c2f437d1
Revolve the ends and Sweep the bend.2
