Dimension and extended direction
ben_jiang418
ben_jiang418 Member Posts: 5 ✭
This might be stupid: Let's say I have a 3mm horizontal line. If I use dimension tool and set the length to 6mm, the line is always extended towards the right, eg, the right end always get moved. Is there a way to move the left end instead?
    S1mon Member Posts: 4,646 PRO
    It depends on how the line is constrained. You want to use coincident (to something like the origin) or fixed, or some combination of the constraint types to the end you want to stay in place. Then the line will grow in the direction you want.
    If any element of the sketch is blue, it's not fully constrained, which makes it difficult and dangerous to predict what will happen.
    I would recommend going through the online training.
    https://learn.onshape.com/courses/fundamentals-sketching
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,382 PRO
    You can fix a point along a line as in this example and it will resize accordingly.
    Show constraints in the sketch should make this clear.
    Try adding a dimension to each of the 3 lines and note direction of change.
    Usually these points are fixed by some other entity.
    Just 1 of many ways.
    https://cad.onshape.com/documents/51c56c763b52d12b01b6f0cf/w/80d72ccf515beaf60ab9a87a/e/00615a870150f26f26892295
  • ben_jiang418
    Got it. Thanks, both.
