inspection items after a release
Jef_Vanthillo
Jef_Vanthillo Member Posts: 4 PRO
hello,
I can not change the inspection items numbers after a release.
The numbers stay grey and con not be re-ordered. I can only delete them and start with a number higher than the highest previous item number. I want to start with nr 1 again.
Is there a solution for this without starting a new drawing?
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,075 PRO
    This is a confusing functionality.  I learned that the inspection numbers are linked through all drawing part number revisions.  So, as long as the part number of the drawing remains the same, the inspection items will not allow you to reuse a number that exists in another revision of the drawing.  If you change the drawing number, you be able to start at number one again.  I think this is a really good thing for the inspection items to do.  ATM, I still haven't quite nailed down exactly why but it feels like it will help keep manufacturing accidents and confusion from happening.
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    @shawn_crocker We are working on removing the block to re-using inspection item numbers after they have been used in a revision.  We will warn, instead.  Stay tuned.
    S1mon Member Posts: 4,648 PRO
    This seems like something that might want to be a company preference with the possibility of an admin override.
  • Wes_Best
    Wes_Best Member Posts: 2 PRO
  • PeteYodis
  • Jef_Vanthillo
    Very nice. Thanks a lot for replying.
  • Jeff_Hubbard
    Jeff_Hubbard Member Posts: 1 PRO
    @PeteYodis I'm, a little confused as this does not seem fixed. Your graphic and current behavior does not have the green check available for changing the number. In order to keep prints clean when we delete or add items, sometimes we want to reuse the lowest #. Also, when the inspection #s get too far out of sequence as you go around the print, we like to delete the inspection items and start with a cleaner flow around the print. I would expect the behavior to be this regardless of if the previous Rev used the # or not.
    1. Remove all inspection item
    2. In Manual or Automatic, restart at # 1 automatically.
    We have figured out a manual work around in the inspection table but is it a pain when you have a lot of dimensions.
    Thank you in advance
  • PeteYodis
    @Jeff_Hubbard we have an upcoming effort to automate a renumbering - and it needs to consider different company perspectives on what is allowed for renumbering.
