How to wrap-solid-add a .dxf image onto a cylinder
daniel_cook028
Member Posts: 2 ✭
I want to add a design of a PNG file I found(I used inkscape to turn it into a .dxf file) and I'm trying to wrap-solid-add it to a cylinder, but when I try it wrap it, a random tiny triangle that's nothing like my picture is wrapped. When I put the .dxf file in I did use the transform feature to shrink it down and move it to the correct place were I want to go. All the parts on my image are closed. Anyway to fix this?
What happen's when you Extrude the picture?0
Hey @daniel_cook028,
Probably best if you share your document so people can have a look at the issue.
Cheers,
David
