How to use shell feature on one face
silas_bastian
Member Posts: 2 EDU
First of all, I am new to Onshape. This is my second project.
I am designing a guitar body, and I want to hollow out a cavity for electronics, and the shell feature seems like the best option. The problem is shell hollows out the whole model like this.
I want it to be hollow only below the selected face. Maybe extrude is a better option? The problem with extrude was I couldn't figure out how to shrink non-proportionally so the thickness is the same around the edge of the cavity.
Welcome to Onshape
You could extrude and start with an offset of your wall thickness.Best regards,
Axel Kollmenter0 -
Another option could be to split you body and only use the shell feature on the right half.1
Welcome to Onshape
Axel Kollmenter0 -
