Transforming .Step files to .JSON file
can_utku
can_utku Member Posts: 3 ✭
For my research project, I need to transform STEP files to JSON file because in working with json is much more easier in Python, https://github.com/PrincetonLIPS/SketchGraphs In this project onshape obtained a JSON data for use. I look onshape's documentation but couldn't see any api for JSON exporter, also in tool it is not JSON file type supported. I just want to learn how we can transform data from step file, Is there an any api for use ? Is it needed commercial usage for that ? Thank you !
