How can I input art in a text?
  • David_YL_Nguyen
    David_YL_Nguyen Member, Onshape Employees Posts: 184 image
    Hey @carlos_macario144,
    It's not really clear what you want to do, can you give a bit more information or share a document?
    In a sketch you can import vector files of your art as .svg or .dxf. Maybe that helps.
    Best,
    David
  • carlos_macario144
    carlos_macario144 Member Posts: 6 EDU
    I haver onde circule, and i would to put text around the circule.
  • carlos_macario144
    Sorry for my poor inglês....
    S1mon Member Posts: 4,613 PRO
    The Surface Text custom feature is one of the better solutions for wrapping text along a circle.
    Rect to Polar can also handle this in a more general/powerful way, but it's slower and a little tricky to use. There are other custom features in the same document which can handle all kinds of interesting warping/wrapping of curves.
