How do I remove the end of an extrusion after it intersects with another extrusion?
daddubz
daddubz Member Posts: 5 ✭
I want to trim the bit in red off the vertical extrusion after the horizontal extrusion.  Not sure how to do this.
Thanks for the help!
  • John_P_Desilets
    John_P_Desilets Onshape Employees, csevp Posts: 281 image
    @daddubz Can you post a link to your document shared public? It's hard to see the bottom of the part.
    A few things to try. Move face to remove the feature. Create a plane (if the extrude feature has a planar face) and use the plane to split the part. You can also try offset surface with a value of zero. Move the boundary of the surface. Use split part using the offset surface as the cutting tool.
    If you share the document it will be easier to test and provide solutions. Thanks!
  • daddubz
    I figured it out.  I needed to split the part with the face and remove the end.
