Why can't I Thicken the loft
greg_najda
greg_najda Member Posts: 4 ✭
Hey Guys,
I'm quite new to 3D modeling and not everything is always clear to me. Most of the time I try to find solutions on my own but this time I stocked.
I'm designing a small hood for my camera. I did thickening the loft in the previous part with success:
https://cad.onshape.com/documents/0a788fb542acb02b1e765304/w/5a2804ef725087370323e76c/e/6c24c3c5778b510c6d8ea736
But when I tried to thicken again using exactly the same technique it was not working. Any idea what happened? Probably its something wrong with me :blush:
https://cad.onshape.com/documents/0a788fb542acb02b1e765304/w/5a2804ef725087370323e76c/e/08d8720878eeba3bf5bd4a18
Would appreciate any assistance.
Thanks
  • David_YL_Nguyen
    David_YL_Nguyen Member, Onshape Employees Posts: 184 image
    Hey @greg_najda,
    They sharp edge/small radius seem to be the issue. When trying to thickening these, this will likely lead to self intersection geometry. Would be best to clean up your supporting sketches and have some consistent radii to have a smooth transition for the loft.
    Hope this helps, let us know if it works.
    Cheers
  • greg_najda
    Hey David. I did some cleaning and it helped. Thank you so much.
