Convert document units of measure from mm to cm
johannes_bichlmayr
Member Posts: 8 ✭
I started with drawings in a document.
My problem is that I started with millimeters, but now I need everything in centimeters.
Can I have everything converted to centimeters?
It is best not to simply transform and scale up.
Example: A measurement is now 30 mm and I want to convert it to 30 cm.
Change your document units to cm. Then use transform.0
