Imprint and merge conformal surfaces during STL export
Andrew_Cote
Member Posts: 2 PRO
I'm trying to export all parts from a PartStudio as STLs such that shared boundaries between two parts share the same node positions—a so-called conformal mesh. Is this possible using Onshape STL export? Selecting Export unique parts as individual files seems to produce non-conformal meshes.
Thanks
Thanks
