Issue with complexish lofting
I'm trying to do a loft on this shape...
https://cad.onshape.com/documents/b00c2db58cb3c00c8457da7c/w/2b9669c0814c77c964667650/e/4f24e3d5e51808bac7a3fd8f?renderMode=0&uiState=64d80ac987e88f26e5dae659 but for the life of me i cannot figure out how to make the software happy to perform it.
The context around this is i'm teaching a lesson on reverse engineering existing items to customize them...
Any suggestions would be hugely appreciated.
Are you trying for a solid loft between the 2 items? OS will not accept a face with an inner opening for a solid loft. You can make a solid loft between two closed faces then a second solid loft (remove) to take the middle out. Open loft 1 and you'll see the error due to selection.
https://cad.onshape.com/documents/00c287c349a9fd9685831061/w/60ac01dcd44d0da641eb114e/e/01b1a29f51af11ad7ee8fa71
BTW your document is view only and cannot be copied to work on.
