Generate BOM that includes automatically calculated total length of part?
Richard_Inv
Richard_Inv Member Posts: 45 PRO
I'm wanting to generate a BOM that includes total length of a part, particularly a Composite Part.
Say I have a gate with multiple posts (all combined into a single Composite part), and need to populate the BOM with the composite part's total length.
(As the posts are all cut from a single length of material in real life)
Is this something OnShape can do natively? If not, any pointers appreciated!
Thanks
  • caden_armstrong2
    caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    You could create a custom computed property that would create a part property for the total length.
    Getting the length of each part in the composite would depend on how its modelled.
    If you are using the frames feature, you could retrieve it from the cutlist properties.
    But if the parts are all just modelled directly, you might have to use some kind of bounding box calculations.
    https://cad.onshape.com/FsDoc/computed-part-properties.html
