<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
have a problem in sweep feature doesn't make the correct
beshoy_nabil
beshoy_nabil Member Posts: 2 ✭
    S1mon Member Posts: 4,574 PRO
    The sweep is self-intersecting. You'll need to break up the problem somehow.
    You could sweep each side as separate parts, revolve the parts of the corners which are missing, and then boolean those all together.
    Or you could sweep the part of the profile which is outside of the sweep path, and then construct the inside separately.
    If you remove the small radii from the path and a sweep like this will work, even though it's self-intersecting. You could add the corner fillets after.
