I'm trying to add a cut list to the part studio:
drew_de_carvalho
Member Posts: 4 ✭
but I get an error that states that it failed to find start and end faces of the frame. I've tried with individual parts and selecting all frames.
My guess is that you add cuts or made some changes "manually" that removed the end faces outside of the frame tools.
You should be able to use "move face" and "replace face" but if you do a cut extrude for example if will eliminate the face created by the tool. Using a "frame trim" might help...1
