Dark and light problem
belal_ayman
EDU
Hello,
I'm facing a problem in the Onshape's interface where the dimension line is black and the drawing panel is also black so when I choose to draw the dimension line outside my geometry in the panel it cannot be displayed
In Onshape, a black screen indicates that you are having a graphics rendering problem. If you are in Chrome, check to make sure hardware acceleration is enabled:
- Go to chrome://settings/
- System
- Make sure “use hardware acceleration when available” is checked.
- Go to chrome://flags/
- Make sure “Override software rendering list” is Enabled.
Is there a solution for that in Microsoft Edge?0
I"m on a mac, but I think this is what you want (Option 1):
https://www.elevenforum.com/t/enable-or-disable-hardware-acceleration-in-microsoft-edge.12116/
That said, I've heard that there are exisiting hardware acceleration issues on Edge, so this might not help.0
