Rack and pinion relationship tool
When creating a "Rack and Pinion relationship", is there a trick to adjust the the pinion and/or rack so the teeth mesh properly?
    S1mon Posts: 4,492 PRO
    Edit the mate connector for the gear and add a rotation around Z of the appropriate angle (probably 1/2 a tooth or something related).
  • paul_schnur
    paul_schnur Posts: 3 PRO
    Thank you S1mon
  • paul_schnur
    Thank you S1mon
