Select multiple constraints
I see that you can click multiple elements to select them all at the same time. Can you do the same with constraints? Sometimes I want to delete or move several constraints at once and doing it for each one at a time is a little annoying.
  • matthew_stacy
    matthew_stacy Member Posts: 489 PRO
    @fernanda_dias, thanks for pointing this issue out.  I had no idea that we don't have a straight-forward intuitive way to select multiple constraints.  I would encourage you to submit an improvement request on this.
