Open Revision button in the Revision History.
wayne_sauder
Member, csevp Posts: 639 PRO
I often wish that when I am viewing a part's or drawing's Revision History via the right-click menu there would be a button along with the view release that would open that particular Revision. I personally find the view release button confusing, (My mind says this will open that rev, and instead, it opens the release dialog which I rarely wish to see with my workflow.) I often do want to open the version of a drawing that has the watermark removed. I realize there are many other ways to get there but I often find that I am in a document and I'll open a drawing and then right click menu on the tab to see what version is the current release, but then you need to close that dialog and go look for and open the rev.
https://forum.onshape.com/discussion/21826/open-revision-button-in-the-revision-history#latest
