Exporting Auto Layout
Hi, ive created a laser joint consisting of two part then Ive used auto layout. Is there some way I can export this auto layout?
Ive tried Kiri but I can only use it for one peice at a time
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 985 PRO
    Accepted Answer
    I usually make a drawing.  Custom template, custom sheet size.  Insert the entire Part Studio.  Then export the drawing for laser cutting.
  • Matt_Shields
    Accepted Answer
  • stephen_topp
    stephen_topp Member Posts: 4 ✭
    Thanks for the help Matt
