What is error: NO MERGE SCOPE SELECTED
Tried to extrude a surface got ' NO MERGE SCOPE SELECTED'
Suggestions?    Murph
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,944 PRO
    edited September 2023 Answer ✓
    @james_murphy562, at the top of the extrude dialog box, there are some merge options (new, add, subtract, intersect). If you don't want it to merge with anything, select "new" instead of "add". If you did want to merge the extrude with another part, you would need to select which parts you want in the merge scope dialog down near the bottom of the extrude dialog box.
    RENDERCAD
  • MichaelPascoe
    RENDERCAD
  • james_murphy562
    james_murphy562 Member Posts: 6
    Thank you so much for your answer.  Murph
  • james_murphy562
