Driven variable in Variable Studio
Yann_Roth_91Yann_Roth_91 Member Posts: 7 ✭✭
It would be really nice to be able to export a measured variable (driven) to a Variable Studio table to be able to use them in another Part Studio or Assembly.
  • _anton_anton Member, Onshape Employees Posts: 525 image
    This could be simple or complicated, depending on what's needed.
    • If you just need to copy the current value (nonparametrically), you can do that manually. We could consider adding a shortcut in the UI, too.
    • If you want it parametric, we'll either need to allow Variable Studios to reference Part Studios/Assemblies and forbid circular references (seems like a... difficult workflow) or introduce a mechanism like Assembly in-context.
    Putting in an improvement request allows us to prioritize these things.
  • MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
    @Puck here is an improvement request that you can vote on: Measured Variables in Variable Studio - Improvement request
    RENDERCAD
