Help with a custom extrusion
willian_tamagi
Posts: 12 ✭
Hi folks, I'm new to the onshape software and cad drawing.
I'm trying to use the extrusion to remove the excess of the frame from my drawing, I tried to use the "Remove up to part" but I'm not manage to make it work.
What I'm doing wrong and what is the easiest way to do this?
https://cad.onshape.com/documents/3ffd866aec2bb976b59bb25c/w/7672397b32ce7e24d0299952/e/844995fde0223b81f98b66ba?renderMode=0&uiState=6527ed8115dc7605c78c3897
Welcome to Onshape @willian_tamagi!
Extrude up to part only works if there are no open gaps in the part. You could fill in all the holes that the extrude is detecting, or you could use the Boolean feature to remove the excess material like this:
https://cad.onshape.com/documents/3fdcc1ca3e15fbfd57233d76/w/12dd884b11268c3513b569c9/e/da6d1287bf...
RENDERCAD
rendercad.ai - Photorealistic product rendering.
________________________________________________________________________1
RENDERCAD
________________________________________________________________________1 -
Hi @MichaelPascoe
Thank you so much for your reply, I tried to use boolean like you used but without success
Here: https://cad.onshape.com/documents/b7b0edb7863a479eed28b238/w/49bf1b74a3577346f44802c1/e/f5da6038635a5271668a98370 -
I closed the hole and changed the order of the work for cut the case only after make the new wall and it worked
thank you for your help Michael.1
